screen filled with lines
@mickey53796 you're not giving us a lot to work with here. It will help if you post some pictures of what your screen actually shows. iFixitでの質問に画像を追加する方法
Connect an external monitor to your Lenovo and see if that shows a clear picture. If so, then the issue is most likely a bad LCD screen on your computer. If an external monitor shows the same lines then the issue is with your GPU on your motherboard.
Use this Lenovo Ideapad 110 14 15 Series Hardware Maintenance Manual to work on your computer (if you do need to change the LCD assembly etc.)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 241
