Hey dont it run
The motor do not run
why
Steffen, you're not giving us much to go on. You say the motor doesn't run; does it do anything else? Is there any kind of indicator light that comes on? There's a red indicator light beneath the warning sign to the top left that can indicate an overheat condition or a damaged overheat switch. If that light is on, I suggest you read up on the vacuum cleaner disassembly guide here.
Miele S828 Vacuum cleaner Disassembly - iFixit Repair Guide
Otherwise you will have to do some basic troubleshooting. Can you use a voltmeter and an ohmmeter? If so, you'll need to disassemble the vacuum and test the power switch then check to see if the motor is getting power.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 24
今までの合計 268
