メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG V60 ThinQ 5G(一般的にLG V60と呼ばれる)は、LGエレクトロニクスがLG Vシリーズの一部として製造したAndroidファブレットです。2020年2月に発表され、LG V50 ThinQの後継モデルにあたります。2021年4月5日、LGはモバイル事業から撤退し、すべての端末の生産を終了すると発表しました。LGは、既存の在庫がなくなるまで同機種は販売されると述べています。
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
画像
画像
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
beaviszep さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 21
今までの合計 207
