メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデルk52t38(Lenovo Vibe K5 Noteとしても知られています)—2016年に発売された5.5インチディスプレイ搭載のAndroidスマートフォンです。シャンパンゴールドとプラチナシルバーが用意されています。
phone switch off not starting
not able to start the phone when connecting to charger only red light comes but does not starts
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If you see a red light when connecting your phone to the charger but it doesn’t start up, it suggests that the phone is receiving power, but it might not be able to boot up properly.
If the phone has a hardware issue with the battery or the internal power supply, it could cause the phone to not start even when charging. The red light may be an indicator of this issue.
In this case, charge for at least 30 minutes to an hour before attempting to power it on. Sometimes, if the battery is deeply drained, it might take a while for the phone to show any signs of life. Ensure you're using a reliable charger.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
i charged the phone and also i removed the battery and added new battery to it but than also not starting what will be the issue in hardware i am technical guy would you recommend me the schedule
additionally i remove the battery and i connect the charger without battery also than also red light was coming but the phone was not starting
さんによる
@rahulyadav37502 If the light stays on even with the battery in and no boot, the issue might not be the battery itself. A failed motherboard, damaged power button, or blown fuse (common in older phones after battery issues) could be at play.
さんによる
コメントを追加
回答を追加する
Rahul Yadav さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 30
今までの合計 264
