How do I open my Sandisk Cruiser?
My Sandisk Cruiser is broken and I'd like to open it up. Please tell me ( or give me a video ) on how to do so.
Mine is a 32GB. It has a top and bottom piece. Look closely at the side edge of yours and you will likely see the joint. They are glued together, so you will have to use a razor (xacto knife) to cut it open. If you do it carefully, you may be able to put it back together.
このアンサーは役に立ちましたか?
I’ll try this later this week. Thank you so much!
過去 24時間: 1
過去 7 日: 5
過去 30 日: 32
今までの合計 184
2 件のコメント
It looks like there are a few different versions of the Sandisk Cruzer; it would help a lot of you could add pictures of your stick from several angles and be sure to include one of any visible damage.
iFixitでの質問に画像を追加する方法
Jerry Wheeler さんによる
I added images to the question.
TheMasterG さんによる
