メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年5月発売の13インチMacBook ProはクワッドコアIntel 第10世代Core i5/i7プロセッサ搭載でIntel Iris Plus グラフィックス搭載(モデル番号 A2251/EMC 3348、4つのThunderbolt 3ポート)
New battery won't charge
During the process of replacing my battery, the battery board cable broke. I replaced the cable with this one from Amazon: https://a.co/d/3S4QvuP However, now it won't charge. The machine boots up fine but the battery doesn't charge. I've doubled checked the power and data connections and they appear solid. I'm wondering if it's the cable or how I inserted it. The leads face up, right? I clamped the plastic locks on both end and it appears secure. Any suggestions?
画像
Here is the screenshot from CoconutBattery showing the new ifixit battery
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would start off installing this gem of an App CoconutBattery make sure you install the correct version for you version of macOS. That should validate if you’ve connected the cable correctly.
I’m not sure in your picture if you’ve set the cables latches. Reference Step 10 in this guide MacBook Pro 13インチ Four Thunderbolt Ports 2020 バッテリーの交換 in this step the ZIF latch is releasing the compression onto the ribbon cable. Also make sure the surfaces are clean and there is no damage or creases within the ribbon cable.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks for your answer! I updated my question with a screenshot showing the info on the ifixit battery.
さんによる
@craiga40961 - Well it does appear the battery cable is damaged or one of the sockets is, or it’s likely the battery is just bad.
We can see the battery status bars are not working as SMC is not getting its data. The static data is being held so at one point it was working.
You may want to see if you can get a replacement battery to remove that possibility. I would also get another cable as well.
さんによる
Thanks, I'll do that.
さんによる
コメントを追加
回答を追加する
Craig A さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 241
