メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年10月に発売された、Apple設計のM1 ProとM1 MaxのSoCを搭載した16インチMacBook Proの修理ガイドと分解情報をご紹介します。モデルA2485です。
MacBook Pro - RAM usage while idle
Hi everyone,
I recently noticed that my MacBook is using around 6.5GB of RAM while idle, with no heavy applications running in the background. I'm currently running macOS Sonoma.
Is this normal, or could there be a memory leak or background processes consuming more RAM than expected? I'd appreciate any insights or suggestions on how to optimize RAM usage if needed.
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Post a screenshot of the Activity Monitor, you can find it in the utilities folder.
さんによる
How much memory does your system have? Typical idle usage of ram is normally anywhere from 20% to 30%.
さんによる
@livfe I just added a screenshot. This device has also a fresh install.
さんによる
@jmehnert 16GB of RAM.
さんによる
コメントを追加
1 件の回答
RAM usage is always tricky! To gain performance the system setup a cache area where the most active data is held (Apps and your work).
So if we turn this into a driving exercise between your car and mine going down the highway it’s likely one will use more fuel than the other. That also holds true with RAM! As you may setup a few more start items or even run a few Apps (even closing them) but the persistence of the cache is still present.
What you want to monitor is memory leaks where a given process keeps consuming RAM and not release it until to restart the system. Leverage Activity Monitor to review things over a period of time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Uas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 44
今までの合計 279
