メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第5世代モデルの修理情報とガイド。モデル:A1387
Battery Replacement, restoring error 29
I replaced the battery in my old iPhone 4s, but when trying to restore through iTunes, it gives me error 29 and everything I’ve researched indicates that it’s the battery replacement that it doesn’t like. The previous battery was completely dead. The phone wouldn’t even boot. How do we resolve this issue?
Edit: Battery was purchased from ifixit.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi David,
Full disclosure here, I don't work for iFixit but I am a volunteer moderator.
That being said, my first suggestion would be to contact the iFixit Store personnel. Their batteries are warranted for a year and they fixed me right up when I had an issue with an Apple Watch battery. Best way I'm aware of is to email them at support@ifixit.com. Explain the issue and ask what your next step should be.
さんによる
コメントを追加
2件の回答
You need to get a battery that has the proper temperature sensing. You could get iPhone 4S Battery from iFixit which should work without issue or the battery from injured gadgets which I can personally verify works fine and is a bit cheaper. https://www.injuredgadgets.com/replaceme...
Replace that dying battery or carry an extra for backup power! 3.7 V, 5.3 Whr, 1430 mAh. Compatible with all iPhone 4S models.の画像
製品
iPhone 4S Battery
$18.99
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did purchase the battery from ifixit, still doesn’t resolve the error.
さんによる
コメントを追加
Hello, for the iphone 4 there are different batterys . You must check the old battery and put a battery with the same APN 616-05... (APN stands for Apple Part Number and you can find this on the battery itself) as the old one. When you have done this your phone will work for sure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Monkman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 25
今までの合計 266
