Storage not showing on pc
My laptop tells me there is no storage. I cant find my ssd storage
@aon9472 check your BIOS settings and see if your BIOS still shows the storage. your computer should not be using a SSD. It uses embedded eMMC. The eMMC "drive" is soldered to the motherboard. It is possible that it may have failed. You could check on here to see if that helps to diagnose it. To actually work on your laptop, use the HP Stream 11 Pro Maintenance And Service Guide
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 191
