メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wi-Fi対応充電式サーマルイメージャー
Replacement LCD Options For Klein TI270 Infrared Camera
Needs some suggestions for finding a replacement LCD. It's a 45pin 3.5" 320x480 TFT LCD. Can't seem to find anything remotely close and customer service wants nothing to do with it. Seem like a waste for a $400 camera since it's just a simple LCD. Looks like the unit runs off a ARM STM32h750.
画像
画像
画像
画像
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @aaronmcmahon,
Can't find replacements by searching for the part number shown on the back of the display.
Without knowing the make and model number of the screen so as to hopefully find its datasheet to get the flex cable pinout and voltage requirements for the screen info etc finding a compatible screen will be difficult if not impossible.
Have you tried checking if it is a backlight problem, that may be related to the motherboard and not the display?
Turn on the camera and then try shining a flashlight at an angle close to the screen and check if you can see any images at all.
They will be very faint if they are there, so trying this in a darkened room may help .
if there are images to be seen, then it is a backlight problem.
Next you have to determine if it is in the display or on the board.
Looking at a close up image of the screen connector (see below) there are two things I check.
a). Check if the diode marked D1 is OK
b). Check if there's battery and ground on the motherboard connector pins that line up with the two highlighted wires, (see image) where the flex cable plugs in. Check with the flex cable removed. Be careful that you don't short them out when using the test probes of your DMM (digital multimeter) as they're very close to each other.
It may be that the motherboard circuit design requires that the screen be plugged in so as to apply power to the backlights. I don't know, it's just what I'd try.
If there is power on the relevant connector pins, then the problem is in the screen.
If there's no power on the connector pins then post an image of the motherboard (both sides).
画像
(click on image)
このアンサーは役に立ちましたか?
スコア 1
11 件のコメント:
I wish it were that easy :( Screen is cracked.... I should have been more specific. Works but most of it you can't see
I've tried searching for the any info on the screen online but can't find anything. I did buy some breakout boards to try adapting a 40 pin screen but seems really tricky. Im pretty sure the pins 41-45 are unused (45 is a ground) so might be possible.
I know nothing about LCDs so this is a first for me. I've seen a lot of talk about Driver ICs but from what I can find on the PCB there isn't one so the ARM might handle that??
Thank you for commenting! I was beginning to lose hope anyone would chime in.
さんによる
@aaronmcmahon
If the screen is cracked you may have nothing to lose by trying to remove the back from the screen and check if there's any circuitry in the screen itself.
Lots of bigger displays have onboard driver ICs
さんによる
Ahhh ok good call. Its cracked beyond and usability. I will have to see if it's hiding any secrets
さんによる
@aaronmcmahon
This may be of interest to you.
さんによる
Thats great! Seems I will need to figure out what mode it uses. Luckily it's not touch so I don't need to worry about that
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
Aaron McMahon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 364
