Drive Belt install instruction
Help on adjusting the Drive Belt.
この質問は役に立ちましたか?
Hi @peyton83066
Here's the owner manual for the table saw that may help.
Go to p.24 to view the procedure to install the drive belt and belt guard.
このアンサーは役に立ちましたか?
I know how to install the belt. I would like a step-by-step way on how to adjust it. When I raise the blade all the way up, the motor is twisting, V-belt is rubbing. Thanks
The only adjustment is described on p.24 when installing it.
Check the Mounting the motor procedure on p.23 to make sure that the motor is secure
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 310
