メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号 A1224 / Mid 2007とEarly 2008 / 2, 2.4もしくは2.66 GHz Core 2デュオプロセッサ
Random shutdown, overheating GPU or CPU suspected
I bought this iMac used and it works ok for a while, but at some point sometimes 30 minutes of use sometimes a few hours, it randomly shuts down.
At first I suspected a bad HDD and replaced with an SSD and replaced the RAM. I'm using a fresh OSX install 10.10 or 10.11 ... whatever this one maxes on.
When the system shutsdown the back of the case is quite warm to the touch. I thought of replacing the Power supply for this system, but they're difficult to find and I don't like replacing electronics that could kill me (I'm not a whiz with discharing caps and the like).
I hate taking this system apart, replacing the SSD in it took 2 hours, but I'm suspecting the thermal paste on the GPU or CPU are the culprit. Any thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
My best guess is that this is due to the GPU overheating, which is a common problem on these model devices. I'm suspecting it might require GPU replacement to resolve. Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How about using diagnostics to see what’s happening and/or use TG Pro often times you’ll see a correlation between the heat buildup and a given sensor firing off isolating where to,look.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
firawe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 209
