メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年6月に発売されたAMD対応PCマザーボード。
White Powder Around Back Of Motherboard
I found a b550 mother board in the trash on garbage day I hope the pictures can show decently
画像
画像
画像
I’m 80% it’s water damage but not entirely sure.
The cmos battery terminal did have a small amount of rust on the inside as well.
I have a cpu coming to test it with. But before I do I wanted to make sure.
I plan on cleaning the motherboard throughly with 99% isopropyl alcohol and a toothbrush.
So my big question is this water damage and is there a way to test it without potentially frying my components? I have a gpu I’m willing to lose but the cpu I don’t want to risk it.
Any help would be appreciated and advice would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @josephcour78263
A short time in an ultrasonic cleaner may be more beneficial as this would get rid of any corrosion in hard to get at places e.g. CPU socket.
The board is looking fairly clean so hopefully there's not too much water damage but given that it was in the trash, you don't know what's wrong with it.
I would gently clean it all over with Isopropyl Alcohol 99%+ but just make sure that you don't get the board too wet as the traces may lift off from the board. Also be gentle with the brush you don't want to remove any components from the board either.
The CPU has been removed (presumably not by you) so maybe the original was OK and that there were other problems with the board that the owner couldn't resolve.
Do you have a DMM (digital multimeter) and know how to use it?
If so, here's the schematic for the motherboard series i.e. MSI 7C95 that may help.
Once you're satisfied that the board is clean etc, go to p.62 in the schematic and view the ATX power connector connections on the board. Use the DMM to make sure that there's no short circuit i.e. 0.00 Ohms, when measuring between ground and all of the voltage rails shown that are connected there. Some may have a low resistance but it shouldn't be short circuit.
If all seems OK, connect the PSU but without the CPU installed and turn it on and check if the debug LED on the board indicates that the CPU is not detected. (You need the power button cable from the case inserted into the appropriate board socket to turn it on - see p.vii 7 of 357 of the user manual) Be alert for any smoke, components showing heat glow etc etc coming from the board so that you can quickly turn off the power to the PSU.
If all appears to be OK, try the CPU and see what happens.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can soak that in isopropyl alcohol to displace any moisture / water. Dry it thoroughly.
I think you can test that without a CPU. Worth trying.
Connect a small motherboard speaker next to the front panel connectors. Connect a CPU FAN. Connect the PSU.
Turn it on. If it beeps then the board is alive. If the fan spins then turns off, there might be a short in the board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joseph Courtney (Joe) さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 496
