Why engine check light glows all time
Why engine check lite glows all time
Most vehicles having EFI systems and other electronics have several indicators with separate error codes related to the indicator; check engine indicator for P type emissions errors/B for body codes/C for chassis codes/U for network codes, ABS error codes when the abs indicator remains on, and airbag indicator for airbag error codes. A reader can decode P type error codes thru the OBD II port under the steering wheel/driver's footwell area. OBD II ports are D type with 16 pins.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 49
今までの合計 315
