The battery is dead
Replace battery
Sorry to say iFixit doesn't have a guide for the repair you need, but the Spanish site Nadie Me Llama Gallina (Nobody Calls Me Chicken) has exactly what you're looking for. The guide is, of course, written in Spanish, but used with the Chrome browser's translation feature, it is quite usable no matter what your native language is.
Manuales / Realme 6 / Drums - Nadie Me Llama Gallina
There is an oddity in the translation to English that will make it easier to understand if you know about it. For some reason the term Battery comes through as Drums in the web page, but comes through correctly in the instructions. Otherwise their guides are well written and complete.
Of course, as long as you're doing the work anyway, why don't you go ahead and take lots of pictures as you work, then you can use them to create your own iFixit guide for those who come after you. It's easy, fun, and you'll have the gratitude of the repair community.
Unfortunately, the Nadie Me Llama Gallina site appears to have been taken over and taken down, so the previous link to their repair guide is no longer usable.
このアンサーは役に立ちましたか?
Battery drained
このアンサーは役に立ちましたか?
You haven't given us much to go on. Is the battery not charging, or is it draining quickly after it's charged? The more detail you provide, the better answer we can give.
Make sure your charger and cord are working, then clean the charging port. If that doesn't help, first step is to change the battery, and possibly the charging port if the battery doesn't fix the problem.
High speed down charge
このアンサーは役に立ちましたか?
If your battery drains quickly, chances are it needs to be replaced. See my original answer for information on how to do that repair.
When I charging the battery It's become too hot
このアンサーは役に立ちましたか?
Although this could be a charging issue, most likely it's caused by a failing battery. Replace it first, then reevaluate and see if it still gets hot.
過去 24時間: 2
過去 7 日: 9
過去 30 日: 34
今までの合計 2,030
