メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 3Gの改良版で、処理速度が高速化されています。このデバイスの修理は3Gと似ており、簡単なドライバーとこじ開け用ツールがあれば可能です。モデルA1303 / 8、16、または32 GBの容量 / ブラックまたはホワイトのプラスチック背面。
Boot Loop and battery not charging
Hi, I have used iphone 3GS model-A1303. I haven't used it for a long time and when i recently tried to turn it on it first displayed a battery flat icon and later it showed me the apple logo and then turned off. I charged it for 4hrs and still the same. So I enabled DFU mode and itunes recognized the device and when i tried to restore it posted that the device was previously in DFU mode now it has been restarted but my device is still in DFU mode. I suspect that this is a battery issue but before buying a new battery i need to make sure that the device is in working state. is there any way to find that or boot into device without battery. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
This sounds strongly like a battery issue to me. In my experience. I have never known and iPhone to boot without a good battery unless you have the ability to connect a power supply directly to the logic board (via the battery connector).
Unfortunately, you'll likely have to get a good battery in it to get it to power on. The fact that it has responded to everything else though is good because it sounds like the system is functioning properly. Just needs a good power source.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@flannelist , ok i’ll try to get a new battery. Thanks for the help.
さんによる
コメントを追加
回答を追加する
4072_Prasanth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 266
