メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus製のConsumer Cellular向けタブレット
How to change battery
Consumer Cellular tells me that the battery is not replaceable. Has anyone disassembled one of these tablets apart to see if that is really true?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Oh it's absolutely replaceable. No matter what Consumer Cellular says. But as far as I can tell this isn't a repair anyone is endeavoring. Most tablets are not designed for easy repair. And I expect it might be tricky to find a replacement part (an exact one anyway).
I wasn't able to find any videos or documentation on how to take this apart but I imagine it will be very similar to most tablets. Either housing is held together with plastic clips, or everything is stuck together with adhesive. If it was made by Asus though, it may be based on some other hardware and just has a custom loaded OS (or custom Android skin) on it instead of the more typical Android. Trying to poke around at Asus to see if I am finding something equivalent, but not having much luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for your reply. I wanted to correct one thing; it is not made by Asus. It is made by Acer. I had hoped that someone else had made this repair so I would know where to start with getting the Grandpad opened up. But that would still leave the problem of finding a new battery that fits. Thanks again for your help. I hope someone else replies with guidance on opening the tablet case.
さんによる
@brent62000
Once you get it open, look for the battery model number which is printed on the battery itself.
Once you find it search online for the model number only to find suppliers that suit you best.
If there's no model number there may be the specifications printed on it e.g. Voltage and current (or wattage) information and dimensions.
The dimensions can be either a 6 or 7 digit number (depending on size) which is interpreted as follows:
!st 2 digits = depth (or height) of battery in mm with a decimal point that is NOT shown
2nd 2 digits = width of battery in mm
last 2 (or 3) digits = length of battery in mm
Example only might be 3.7V 5000mAH (or 18.5W) 407095 = 3.7V 5000mAH 4.0mm x 70mm x 95mm LiPo battery. Also check whether a 2 or 3 wire connection is used between the battery and the motherboard as some motherboards require that the battery has temp monitoring capability i.e. thermistor connected on 3rd wire in battery, whereas others mightn't.
さんによる
コメントを追加
Hello. I was just able to replace the bulging battery in my mother-in-law's Grandpad earlier today. It took a good bit of research, but I found a suitable replacement battery on Amazon from brand FITHOOD. The original battery (1ICP3/100/107) seemed to match size and pins with the battery model AP14F8K that Acer uses for some of its Iconia tablets, and it was delivered by USPS today. The hardest part of the process was freeing the adhesive holding the old battery in place. Now there's no more bulge in the back of the Grandpad, all functions work as usual, and it can charge sitting in the cradle again.
Hope this helps somebody.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brent さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 54
今までの合計 912
