メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年に発売されたDell XPS 13ノートパソコン、モデル9343および9350に関するデバイス情報と修理情報。
M2 Screws for battery replacement
Hi - I want to replace the battery in my Dell XPS13 and need the three M2 x 2 screws to hold the battery in (managed to lose them). I can get M2 x 2.5 but can't find anyone who stocks M2 x 2. Can anyone suggest a source OR can let me know if I can get away with M2 x 2.5 - I suspect they may be too proud. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @mick26213
Please confirm the model number of the laptop?
Looking at p.18 of the owner manual for the model you selected, it shows that there are 4 screws securing the battery.
How did you verify the length of the screws and what is the screw head diameter, so that it will sit in the battery screw hole? Found a few suppliers for M2 x 2mm but they had different cap (screwhead) sizes, e.g. M2 x 2mm x 6mm (cap) which mightn't work if it is too big
さんによる
@jayeff Thanks for getting back - it's the 9343/9350.
iFixit had the M1.6 x 4 fourth one but not the M2 x 2s. The length is in the ifixit repair guide and marked on the old battery itself. I've measured the cap size because they are countersunk in the battery and it is 6mm. So grateful if you can share a possible supplier.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @mick26213
Might depend on your location but here's the supplier I found.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Mick さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 16
今までの合計 380
