メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
キッチンやバスルームのシンク、蛇口、水栓の修理ガイドとサポート。
Kitchen faucet aerator replacement
Hi all.My kitchen faucet aerator needs to be replaced.Can't figure out what parts I need so forth.
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @ag8079305
What is the make and model number of the faucet?
If you remove the rubber o-ring above the white plastic aerator (as seen in the first image you posted - part on left side) then the aerator should come out.
Here's a link that may help.
Complete aerators i.e. aerator and housing, usually the housing comes in two types, male and female. Those that have a thread that screws into the faucet spout and those that are screwed onto the faucet spout.
Looks like yours is a female thread aerator. Mostly spouts are of a similar diameter so you should be able to find replacements at any good hardware or plumbing supply store.
画像
(click on image)
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
It's a glacier Bay not sure exact model though.
さんによる
@ag8079305
Did you get the white plastic aerator out OK?
You may have to take the complete aerator assembly to a plumbing supply or hardware store and see if you can find a match.
さんによる
Yes I was able to remove it
さんによる
@ag8079305
Usually they don't need replacing unless they're damaged.
If the water isn't coming out OK mostly they're just clogged with sediment/grit that builds up over time.
Sometimes the o-ring needs to be changed though.
さんによる
The aerator itself is a little gross but the other part that it attaches too.The part on the right in the top picture.It is damaged.Not sure how overtime I guess.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Ag80 さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 10
過去 30 日: 32
今までの合計 1,078
