メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The camera lens does not open.
When I start camera lens don't open.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hello!
Usually, when a camera lens/shutter does not open, it's usually because their is some grit or grime that has gotten into the shutter (You might hear a grinding noise when the camera comes on and get a lens error). Cleaning the area with alcohol might help.
There is also the chance of the motors that open the shutter may be failing, which are difficult to replace.
As a last ditch effort, you could attempt to replace the battery, since old batteries might not be giving enough power to actually open the shutter even if the rest of it manages to power on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@ugur94457 that is one of the most common errors on digital cameras. Start of by trying to fix this with the few tips that are listed on here I found that most often the lens is actually damaged and requires a replacement.
Download the service manual from this page Sony Cyber-shot DSC-W35 under Documents. Page 9 and on, will show you how to disassemble your camera. It really is not complicated and lenses should still be available. It's a great little camera and a worthwhile fix.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ugur さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 67
今までの合計 1,281
