メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Panasonic製ビデオカメラの修理ガイドとサポート。
How to fix a scratch lens
Hi, everyone, I have a couple of Panasonic camcorders in perfect shape other than I got a tiny scratch on the front lens on both camcorders, so when you record, certain ways the light enters the lens you see what looks to be a tiny bit of dust on your recording, and many people may not even notice it but I do a lot of filming and it bugs be crazy! Can I fix this without changing the lens which is nearly as expensive as the camcorder? Thanks for the help!
Update (12/09/24)
Panasonic HC-WXF1 and a Panasonic HC-VX1
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
wow thanks for your help, but that first lens(7:51 marker) that's removed is all I need! Where can I get this?
Thanks again!
さんによる
So you feel the steps would be the same to replace the same lens on a Panasonic HC-WXF1 camcorder?
Thanks
さんによる
コメントを追加
1 件の回答
ベストアンサー
@dmd31052 looks like you can get to the lens, but it is a bit of a PITA. See if something like {https://www.youtube.com/watch?v=1SLOYc4g... |this video] will help you to get to it. We'll continue to find some better material to assist you further.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
DMD さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 21
今までの合計 270
