Top screen rubber stoppers
Hi, the top screen rubber stoppers on my device are crumbling/perished I was wondering if anyone here had ever replaced them and how easy it would be to do
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Toby!
You mean the rubber pads on the side of the top screen?
If this is what you meant, then they are very easy to replace.
The part: https://www.aliexpress.com/i/32568050961...
There are many colors available.
You can remove it easily with tweezers and put the new one back on it.
このアンサーは役に立ちましたか?
Hey! i know this post is 2 years old but i have the same problem, and question is how do i stick those rubber pads? like is there some special glue or what?
Hi!
No glue. You can simply use double sided tape (very small ones) and that should do the trick :).
過去 24時間: 1
過去 7 日: 12
過去 30 日: 79
今までの合計 2,043
