メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
20回答 すべてを表示
Logic board swap for 13" MacBook Air 2011 A1369
So I have a running A1369 13" 2011 MBA 4gb ram and an i7. Amazingly it's running OS15.1 but it's definitely maxed out its resources. Only the SDD has been upgraded but the 4gb are not pulling their weigh. Physically it looks like the 2012.1466 logic board should fit and comes with a faster i7, 8gb of ram at a price cheaper than if I just wanted to buy those components separately an start soldering. I'm due for a new battery anyway so upgrading is a non-issue as they're all the same shape and model. Saw some comments about the monitor and camera but don't see any real hard facts - anyone pull this off yet?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Before you make the jump review the guides and compare the parts I would also review the model info from EveryMac - MacBook Air systems
The Ultimate Guide to Apple’s Proprietary SSDs the 2011 systems use a different blade SSD which means you’ll need to get a replacement that meets your needs.
Get an 8GB system for sure, as a 4GB system is too lean memory wise which tends to wear out the SSD.
You may want to run the numbers to review your costs, I’m sure you can find used systems which other than a worn battery will more that meet your needs for a lot less! A i7 with 8GB and 1 or 2TB SSD. I just snagged an Early 2013 for $240 as a Xmas gift for a 12yo I tutor.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I haven't had a 2010-2011 model but I think the 2011 and 2012 share the same I/O board for the camera connection and microphone connection on the I/O board, so a logic board swap should fit and work. Also, It may get complicated also with the track pad as I am not certain they are the same so you may need to swap that over also..... It gets a bit more complicated after 2013 models for a board swap etc as I am often in the situation of finding parts from other non repairable units and hit snags especially with I/O boards and microphone connections....I have seen some YT videos upgrading the RAM to 16GB but am not sure if it is possible on 2011 models. The fastest you'll get of this generation of MacBook Airs would be the identical 2015 & 2017 i7 2.2 Ghz versions which both have the 8 GB RAM and run OS 12 Monterey.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The 2012 logicboard's screen and battery connector won't fit in 2011 case. Screen cable is too short and battery connector is different.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
He did mention he would replace the battery which according to ifixit list A1369 & A1466 to be of the same design and compatible?, MacBook Air 13" (Late 2010-2017) Battery so that would leave the LCD cable & hinge assembly changed then it maybe possible to do?
さんによる
コメントを追加
回答を追加する
john7774 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 12
今までの合計 49
