メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nokia電話機のメーカーによる、HMD Skyline Business Editionの修理、分解、トラブルシューティング情報。Skyline Business Editionは、Skylineと同時に2024年7月に発売されました。
How to hard reset
How to hard reset
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
Did you ever find a solution to this?
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi @brianwofford
Here's a link that may help.
Note: Be aware that performing a hard reset will enable the Android FRP lock (factory reset protection) feature. If the phone has a Google account associated with it this means that after the reset to access the phone again to set it up will require knowing the account user ID and password.
If you can still access the phone before performing a hard reset (either by using the settings in the phone or the phone buttons) then remove the account from the phone (and also the phone from the account - login to your account online to delete the phone) then perform the reset.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
This does not work on the HMD Skyline.
- Volume Up + Power simple reboots the device. It does not bring up bootloader, fastboot or anything else. Its a functionless key combination on this phone.
- Volume Down + Power at least brings you into the fastboot menu, although your only options are "Start" "Restart Bootloader" or "Power Off".
Which means for hard reset or recovery, both key combinations are useless.
I have contacted HMD, who at first replied with the same standard "Volume Up + Power" function. However, I obviously pointed out to them that it does not work. I am still awaiting feedback on it from them.
However, should I not get it promptly I will just return the device as it is of no use to me if I can't access it. I am sure they themselves have all the tools required for a factory reset. But they (and iFixit) can be sure I won't be purchasing another HMD device if something as basic as the standard android recovery does not work - no matter how "repairable" it may be.
さんによる 共有
How do U this I forgot my pin and will not work
さんによる 共有
how to unlock my skyline hmd phone if forgot password
さんによる 共有
Simply put: you can't. I ended up returning my device because the only option HMD gave me was sending the device in to have their service team reset it.
To me it is pointless to "own" a device I don't really own. You can't even reset it with the standard android procedure that requires the posterior Android FRP unlock, which means it is vendor-locked even more than most other android devices (ironically including even the Google Pixel which is the most secure device available due to the M2 Titan).
さんによる 共有
コメントを追加
回答を追加する
Brian Wofford さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 79
今までの合計 1,727
