メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
この5G対応Moto Gは、6.5インチ720×1200ピクセル90Hz液晶ディスプレイ、MediaTek MT6833チップセット、ワイド50MP、マクロ、深度カメラを搭載している。
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kishore Kumar S さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 370
