メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
Disconnect monitor from power
My old iMac runs HomeassistantOS. I don't need the monitor for this and it just uses unnecessary power. How can I disconnect the monitor from power as soon as the machine is running? I am thinking of a switch on the side of the housing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Surprisingly, the LCD and the backlight (CCFL in this series) are both very low power consumption. Just turning down the brightness kills the backlight. I would leave it alone, the risks of messing up is not worth the risks.
I had a 2011 Mac Mini which I ran HomeAssistant for a while, I ended up jumping to Apples HomeKit as I wanted the better HomePod integration.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
How can i turn down backlight? That's all software (MacOS) based. And there's nothing on the disk.
さんによる 共有
@baschdler58184 - Sorry forgot about the OS, as I was on a Mac Mini. I’m sure someone has created a Linux tool which would work here. Even still the backlight is not that big a draw.
さんによる 共有
Nope ... i searched the entire Internet from one end to the other without success. Only guys who have the same issue.
But I am not giving up!! Not me!!
And it's not possible to add some screen drivers to HAOS – I am not the first one thinking of this solution.
さんによる 共有
@baschdler58184 - Sadly this is a square hole, round peg problem. I’m not a good enough programmer to get into creating something and again iMacs are just not the ideal platform because of both size and the screen.
If you have the time and skills I think this would be a rewarding project to tackle creating the needed software to do this. But again, while it would be nice this is not the bigger consumer of power in the system, that would be the CPU and the rest of the running logic. As I too didn’t want something sucking down power all day long also pulled me into HomeKit.
さんによる 共有
I tried Homekit together with Homebridge on a Synology NAS but I am really not satisfied.
In Homeassistant my Router shows 20 "entities", in Homebridge nothing, in HomeKit it's possible to switch it ON/OFF ... that's exactly what I expect from a smarthome integration of a router ...
Same with my Shelly Plugs. I can just switch them ON/OFF. And that's what I don't need - I use them to measure power consumption. The switch is obstructive and dangerous. If I switch off my refrigerator by mistake all steaks will be gone the next day. But Homekit does not show the measurements and does not show the trajectory.
さんによる 共有
1以上のコメントを表示
コメントを追加
回答を追加する
Baschdler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 239
