メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月発表。モデル番号はJ8210、J8270、J9210、J9260です。
Mobile is not working
My mobile is not turning on and not charging and also pink line issue
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@abdulahadq78484 if it is not turning on how do you know it has a pink line issue? That line issue will most likely require you to replace the screen.
As for the rest, first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this makes a difference, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Abdul Ahad Qureshi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 215
