Power on but no display
Try disconnecting all devices and peripherals and reconnecting them again. The most common issue is a faulty hardware. So, try replacing it or check the troubleshooting errors. You can also perform a System Restore.
このアンサーは役に立ちましたか?
First, if you have an external monitor you can connect it using a cable, if the monitor can display what is on the laptop then the laptop screen is damaged.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 266
