メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleの13インチMacBook Pro Retinaディスプレイモデル(A1502)は、第5世代のIntel Core i5およびi7プロセッサを搭載し、感圧タッチトラックパッドが導入されました。
Replacement battery age requested before purchase
Hello,
Can I find out the manufacturer date for an iFixit replacement battery before purchase?
Background: I recently had a shop replace my original Macbook Pro 12.1 battery (13 inch early 2015). The aftermarket (Simplo brand) battery is hotter than a Texas bbq, and after only 16 cycles it's already dropped to 94% capacity. I have installed a fan controller app to turn the fans to full blast, which helps with the heat but destroys the battery time between charging. Today I installed CoconutBattery and saw that the manufacturing date of the battery is March 2015. When it was installed it had about 20% charge, which I thought was low, but I didn't think too much about it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This is the repair forum, and I'm afraid the iFixit Store personnel don't hang out here watching for questions. You'd be far better off contacting them directly with your question. Best way I know of is to email them at support@ifixit.com.
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
Many thanx. Will write directly.
Regards.
さんによる
Coconut Batter is NOT always accurate with battery dates.
Coconut Battery app discovers a gem ;);)
I recently put a new battery in a MB Air 2018 and the date was 2015!
Had numerous circumstances with these incorrect dates.
さんによる
@livfe - Well… that’s not correct. The report of what the batteries microcontroller reports is the data of the microcontroller. If the microcontroller is reused then you will get the original date programmed. This is not CoconutBattery error.
さんによる
@danj How is the microcontroller reused? They salvaged from old discarded batteries or NOS new old stock would be more likely.
さんによる
@livfe - During COVID the battery makers couldn’t get the part so it was a way of survival for there business big or small! They grabbed what they could. Some I didn’t have the tools or skills to burn the chips firmware and/or program the non-volatile storage area these chips (ROM) have hence bad date. That’s assuming they got access to the virgin chips.
It doesn’t matter in the end SMC polls the chip and you get what it holds, in our case CoconutBattery is just allowing you to see it.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
andersmard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 331
