cd drive cannot eject. no respond
cd drive not working. open manually. not respond when place cd
@panjibaru sounds like a failed drive but check the power supply to the drive and see if it has the required voltage on that circuit. Check your BIOS to ensure that the drive can still be seen in the device list. Ultimately this sounds like you will need to replace the drive.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 8
過去 30 日: 29
今までの合計 185
