Sensor of the mouse automatically started working inverted
While playing once the mouse in between games suddenly acting strange begins to work inverted. I guess the sensor is busted
Hello Ajay.
The problem you are currently experiencing may be a software bug or hardware bug. Try going to Settings > Bluetooth and Devices > Mouse > Additional mouse settings > Hardware. And then next to "Device Status", it should say "This device is working properly."
If not or if it does but the mouse is still broken, that means the problem is in the hardware, and you should do one of the following:
Thank me later.
このアンサーは役に立ちましたか?
@ajaybhatia67034 you are saying "the mouse in between games" but you are not telling us if it works properly in the games. This could easily be a software issue. I'd start by either updating or replacing the device driver for your mouse.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 32
今までの合計 415
