Why monitor screen upside down?
How to fix my TV monitor screen upside down?
Model Code: UA32N4000ARSER
Version No: CA02
@christophe25821 try to access the service mode for your TV. On your remote hit
POWER OFF==> MUTE==> 1==> 8==> 2==> POWER ON
if that does not work try
POWER OFF==>INFO==> MENU==> MUTE--> POWER ON
Then under the Options Menu you may have something like MRT Options, select that. There you should find something like HV flip. Give that a try. Some menu options are different due to different firmware version etc. If you can't immediately find it, keep looking for it but do not change any other items.
If your can't fix it with the Service mode then the issue could be a bad EEPROM on your mainboard. Sometimes a reprogramming of that will fix the inverted screen issue. This will require the exact firmware for your TV model, which is sometimes hard to find. In those case either a new EEPROM or a new main board should fix it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 62
今までの合計 470
3 件のコメント
My tv picture is down passion
Raghul S さんによる 共有
আমার স্যামসাং মনিটরটি 180 ডিগ্রি ঘুরে আছে
Toqi Ullah さんによる 共有
@toqiullah if your TV is the same model you need to try the steps listed in the answer.
@toqiullah আপনার টিভি যদি একই মডেলের হয়, তবে উত্তরে দেওয়া ধাপগুলো অনুসরণ করে দেখতে পারেন।
oldturkey03 さんによる 共有
