メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
カラーサンライズシミュレーション、5種類の自然音、ラジオ機能付きPhilips Wake-Up Light目覚まし時計。2017年4月発売。モデル番号:HF3520/60。
How to fix lamp always on?
I bought a HF3520 second hand, and everything works fine except that whenever the lamp should be totally off it is at full brightness.
For instance, if I press the lamp button the lamp turns to however bright/dim I've set it, but if I press it again it turns to full brightness.
I've tried disconecting it for a while, and reseting it but nothing has worked.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Did you review the owners manual? Here’s where you can download load it HF3520 info
I’m suspecting the settings are off either AM - PM confused or the time zone setting.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Thanks for the reply!
I checked the manual. I changed the time setting and that didn't fix the issue, also the lamp function should be able to be turned on and off regardless of the time.
さんによる
@ericastrue - Then the switch is bad or the logic which controls the lamp.
I have HomeKit version of the lamp and have it programed with Siri as well via my HomePod Mini. My first unit was defective as the control logic was bad.
さんによる
I see, maybe it's a different model as with mine I don't think I can conect the device with other devices.
さんによる
@ericastrue - Sorry, I may have confused you. If the settings are correct then it’s the switch or the logic which controls the light. Best to find someone with micro electronics skills to help you locally.
さんによる
Someone on reddit told me about having a similar issue, and in his case it was a fawlty capacitor. I've dissassembled the light today and I've found that that same capacitor has a slight bulge on the top in my unit. I'll try to test it tomorrow and replace it, and I'll get back to this thread.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Eric Astrue さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 40
今までの合計 483
