メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
What to do with my iPhone
I dropped my iphone on the ground, It landed on one of its edge however the screen was okay, but the when I opened it, the screen doesn't response it was all black but the vibration from the flashlight and camera was still functioning. Is it the LCD or the connectors?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Kelsey,
Fortunately for most of us, Apple does a very good job of locking down all the internal connectors on a phone so that they pretty much never come loose no matter what kind of falls or impacts they receive. Sadly that's not good news for you, as it means you won't be able to fix your screen by opening up the phone and reconnecting a loose plug.
My two grandchildren were both given iPhone X phones, and given their youth I have quite literally lost count of how many screens I have replaced between the two of them. So trust me when I say that you will have to replace the screen. Even though the glass wasn't damaged, there are still delicate connections between the flex cable going to the motherboard and the glass the OLED circuits are printed on and it's all too easy for those connections to get damaged due to a drop.
The good news here is that iPhone X screens have gotten to the point where they are dirt cheap nowadays. The last one I bought from AliExpress was only $14 USD and that included free shipping. Here's the listing:
AAA OLED For iPhone X XR XS MAX Display 3D Touch Screen Digitizer For 11 Pro 12 Mini 13 Pro Max 14 Plus 15 LCD Replacement Parts - AliExpress 509
Be sure to select the X - OLED button and not the X - INCELL link; you don't want the LCD version, especially with the OLED one being so cheap.
Note that the screen I've linked to doesn't come with the green plastic frame that holds the earpiece speaker assembly, so you will either have to salvage the one from your existing screen or order them when you order the screen. They're dirt cheap; I got 10 of them for $1.20.
10pcs Front Camera Proximity Sensor Plastic Bracket Holder Clip For iphone 5 5s 5c se 6 6s 7 8 plus X XR XS 11 12 mini Pro Max - AliExpress 509
And of course you'll want a guide showing you how to do the job and iFixit has your back; here's the screen replacement guide for your phone.
iPhone X Screen Replacement - iFixit Repair Guide
The other thing you'll need to do the job right is a sheet of precut adhesive to glue and seal the new screen onto the phone. Here's an example of that being sold here on iFixit, but again that's something you can get on AliExpress as well if you need to save money.
iPhone X Display Assembly Adhesive
Good luck and let us know how it goes!
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone X.の画像
製品
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kelsey Aneth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 62
