メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo DSは、任天堂の第7世代携帯型ゲーム機であり、折りたたみ式のGame & Watchシリーズを除けば、全システムの中で初めてデュアルスクリーン技術を採用した製品です。
Audio doesn't work
Good evening, I received a Nintendo DS which works perfectly except for the audio. Before trying to change the speaker, are there any other ways to fix this? Luca
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Luca!
To be honest, I think it’s strange that the 2 speakers are dead. I don’t think it’s speaker related. You can try to swap them (as it’s still is a possibility that they are both dead). It’s very easy to replace them for the original DS (no soldering needed).
Now, it’s very possible that the speaker boards (where the speaker is connected to) are broken and need to be replaced! To give an idea, you can follow this guide: Nintendo DS 上部 LCDスクリーンの交換 (till step 16).
It’s also possible that the audio IC died. But let’s try the other 2 (more easier) options first!
Please let us know how it goes!
EDIT photo DS original motherboard:
画像
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Good afternoon, I removed the motherboard from the shell and I tried test it with some "GOOD" top parts that i obtained fixing others nintendo ds and I discovered that all of them do not play any sound. So I tried test them also with a headphones with jack but is the same… What should i do now? Luca
さんによる 共有
Hi Luca! So, you took the motherboard from the "No sound DS" and tested it on other DS consoles and there is still no sound?
if this is the case, it probably is the Audio IC.... This one is difficult to fix.
You need soldering experience here to get it fixed.
I'll upload a photo regarding the components on the original DS motherboard, so you can decide if you want to fix it or not!
POST UPDATED.
さんによる 共有
Can i find this chip in others console like DS Lite? Luca
さんによる 共有
Yes! It should be on every DS motherboard. If you are in doubt, please share some pictures with us! Thanks!
さんによる 共有
コメントを追加
回答を追加する
Luca Di Renzo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 956
