Side panel wont open
The lever on the side of the mac wont come out fully, and because of that i cannot open the side panel. Any tipps to how I can fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
SOLVED! Turns out there was a loose screw stuck in the latches inner part and because of that you couldn’t pull out the latch fully. The solution I came up with was to turn the whole mac upside down dislodging the screw.
このアンサーは役に立ちましたか?
Is the lock enabled? You could try a little WD40 sprayed into the handle area. Don’t over do it, a little goes a long way.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 15
今までの合計 192
