メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Anywhere Mouse MXは、2009年にLogitechから発売されたレーザーマウスです。このマウスはLogitech Unifyingレシーバーを介して接続し、単3形乾電池2本で駆動します。
I have broken a pad SW1 (again)
Hello!
I have broken my second Anywhere MX 1 mouse when replacing the SW1. The pad broke again near R6 (signal one, the ground is fine) and I was certain to not break it again. But it happened.
Is there any chance that anyone has got the schema or idea where the signal comes from? I would love to make a jumper and get my favorite mouse to work.
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
is this copper, can't tell with the flux
画像
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I've edited my post and added photos of front and back. I've checked the C6, which appeared to be connected through a hole, but that side od capacitor appears to be a GND.
さんによる
Nope - it is a PCB. The pad fell off. The only thing that is copper is the little hair trace that's left.
さんによる
@makerbuddy have you got a multimeter
さんによる
Yes I do, so I could tell that the trace goes to ground.
Besides I was working on it and today managed to catch the copper trace that was left from the pad. Used some copper wick as a new pad and everything works fine.
Besides that I still did not got idea where it goes! I've checked every component and signal points, but none of them was giving a beep in continuity test with multimeter...
さんによる
コメントを追加
回答を追加する
MakerBuddy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 328
