メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS Rebel T3は、Canonのエントリーレベル一眼レフカメラであるRebelシリーズの系譜を受け継ぐモデルです。EOS 1100DやEOS Kiss X50としても知られており、12.2MPのイメージセンサーとDIGIC 4画像処理プロセッサーを搭載しています。
Camera taking black photos
My camera is taking black photos only in manual mode you its black when its in live mode also I've changed all the settings yet its still black when you put up the flash you can see it though live mode and take photos using the flash
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
It's only with manual mode that you're having this issue?
If it is, are you sure that you're that you have the aperture, shutter speed, and ISO set correctly for proper exposure? When you're taking a photo, look at the exposure level indicator to check (the scale on the screen that goes from -3 to +3). Underneath the scale should be a vertical bar which shows you the exposure level. Ideally, the bar should be close to 0. If the bar is all the way to the left by the -3, then the camera is just not getting enough light. If that's the case, you need to lower the aperture, lower the shutter speed, or increase the ISO until the bar is closer to the 0 on the exposure level indicator.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@gxlpe that could be a shutter problem as well as a failed CMOS sensor. Since we do not know what the shutter count on your camera is, the shuter may just have been "wore out". The life expectancy for the shutter for the Rebel T3 is ~100,000 shots. Here is the Canon EOS Rebel T3 EOS 1100D Parts List for your camera since no service manual appears to be available. It will at least give you an idea where the shutter assembly is and what it entails.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If the back display is showing an image the CMOS sensor is working, when looking though the eyepiece with the shutter set on a long exposure does the image go out (become dark) if that happens then you know the reflex mirror is moving out of the way, often times this is the failure.
That only leaves the mechanical shutter which sits in front of the sensor. This is used when the camera is taking high speed images like older film focal plane shutters to limit the exposure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gxlpe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 31
今までの合計 364
