メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Weird screen behavior M30S
My screen was working fine, until it started acting really weird, and nothing could be really explained except by pictures of the issue so I uploaded picture of it
As it appears, on the boot the screen work normally except when enering the system that's where it gets weird
画像
画像
画像
画像
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@fatimazahr72439 try to start your phone in safe mode and see if that changes anything. It is possible that this is software related, maybe a bad third-party app etc. Use the Samsung Site to show you how to get in Safe Mode.
If it works okay in safe mode, you will have to start removing your third party apps until you know exactly which one is the cause. If it still happens in safe mode, then the issue could be a screen issue.
Update (10/02/24)
@fatimazahr72439 this doesn't look like flashing the ROM would resolve it. this does look like a bad screen. Replacing the screen will most likely resolve the issue. Since ifixit does not yet have a specific guide for this, use something like this video Replacement screens are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for assiting, but the phone booted into safe mode with the same issue, and since there important data in the phone, I'm gonna dissaemble it and try a new screen to check and if it not the screen then I'm gonna try to flash a stock rom or check if the motherboard is causing this issue,
Thanks again I just posted here to know if there was someone in the same situation as me before and managed to solve it.
さんによる 共有
コメントを追加
回答を追加する
Fatima Zahra KHATIR さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 17
今までの合計 285
