メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年6月、Appleは13インチ MacBook Airのプロセッサを新しいBroadwell Intel Core i5にアップデートしました。これにより、わずかなパフォーマンス向上とバッテリー駆動時間の延長が実現しました。
Can not boot Showing Blue Screen Recovery
My macbook while trying to reset and reinstall MacOS suddenly showing blue screen Recovery and stating:
"Recovery
Your PC/Device needs to be repaired
A required device isn't connected or can't be accessed.
Error code: 0x0000225
You'll need to use recovery tools. If you don't have any installation media (like a disc or USB device), contact your PC administrator or PC/Device manufacturer.
Press Enter to try again
Press F8 for Startup Settings"
Enter and F8 does not work.
Trying to place it on safe mode does not work.
Can not go to any other mode other than this blie screen.
Please help 🙏
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Before I can give the answer to this, did you have a dual boot system installed before? (Mac & Windows) ?
さんによる
Hi! No dual boot system installed.
さんによる
Thank you very very very very much!!! Above instructions/solutions followed to the letter and now have restored / reinstalled MacOS 🙏🙏🙏
さんによる
Great :) Glad to hear your back up and running.
Can you edit the title adding Error code: 0x0000225 ;)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Power up and hold the option key , do you see choices of boot device?
IF you see more than one then one of them will be your MacOS, boot into that and do a backup or at least copy all your files to an external drive for safety. If you can boot into your previous Mac installation then install Mist and download a copy of MONTEREY which is the last supported OS for this Mac model and create a bootable USB from this (Mist can do this for you, it's a great app).
If I am not mistaken this blue window indicates that there was at some time a windows installation on the unit as I have had this occur after an unsuccessful windows installation or if windows had been incorrectly deleted from the main drive leaving some bootcamp files or partition as the Error code: 0x0000225 is defiantly Windows related. The best way I can suggest providing you couldn't boot into Mac to make a bootable USB as previously mentioned above would be to Create a bootable installer for macOS (Monterey). You'll need access to another mac to do so, once done, go back to the MB Air insert the bootable USB, power up and hold the option key to get into recovery mode. Once in recovery mode, go to disc utility, select the internal SSD from the list on the left side, at the top on view options check show all devices, then select the top volume (Select APFS and GUID Partition Map from the option window) and then hit erase. Take note to check that there is only one partition on the drive, this is very important as this will delete all boot files and partitions which are causing this issue! One way to double check closely would be to hit partition in the menu and see if it displays more than one partition, if indeed it does then you have to minus them all off until only one partition is displayed. Once erased exit disc utility and proceed to install MacOS. Hopefully that resolves it and you'll be good to go. This would be my quickest solution as trying to delete these boot camp partitions can be a little tricky and frustrating let alone time consuming as the blue screen can still pop up upon booting. A total fresh wipe and install will cure this permanently. Hope that helps!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Itchi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 36
今までの合計 938
