メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010年に発売されたSony Cyber-shotカメラのW330モデル、デジタルスチルカメラシリーズ。1410万画素、光学4倍ズーム、3.0インチ液晶ディスプレイを搭載。
Why is my screen white?
So, I cracked my LCD a while back so I ordered a replacement off of eBay. I just replaced it, and I was testing it and the screen is white. When I turn my camera on, the lens opens but then retracts and the screen stays on. I was pretty gentle when I was replacing it, and the only reason why I replaced the old LCD was because it was cracked.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
Just tested my old LCD and it doesn't turn on at all. I'm guessing I messed something up >:(
さんによる
@ellasimones not necessarily. Try you new screen again and see if it still shows white.
さんによる
@oldturkey03 tried it as well and same thing :(
さんによる
コメントを追加
1 件の回答
@ellasimones so it remains black no matter what (old or new screen)? The white light means that your LCD receives the backlight but no video signal. So you'll have to check the connector where the LCD plugs in and check for bend, broken, corroded pins etc.
The backlight and the video have separate circuits. For the video processing you would have to check the IC201 which is the signal processor on the on the SY-243 board.
Basically what you want to do for now is to disassemble your camera and check the board for anything odd (missing or burned) component.
You can always post some pictures of that board with your Question so we can assist you with that. iFixitでの質問に画像を追加する方法
Also, you can now download the Level 2 and Level 3 SM from the bottom of this page Sony Cyber-shot DSC-W330. It'll help you with finding the components as well as trying to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ellasimones さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 40
今までの合計 705
