メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PDP Afterglow Deluxe+ Audio Wired Controllerは、4色調整可能なLEDを搭載し、Nintendo Switchのゲームサウンドを直接聞きたいプレイヤー向けのオーディオジャックを備えています。
How to fix stick drift
Stick drift fix
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Stick drift is annoying, but it is worth checking whether it is dirt, calibration, or a worn stick before you replace anything.
First, do a rest test: put the controller on a flat surface, do not touch the sticks, and watch the character or cursor in a game or in the Switch controller settings. If it moves on its own at rest, that points to drift rather than just a sensitive game.
Next, rule out the connection. Since this is a wired controller, try a different USB port and, if you can, a different cable and a different Switch or PC. If the drift follows the controller, the problem is in the controller, not the console port.
Then try cleaning and recalibrating. Gently blow compressed air around the base of the stick, rotate the stick slowly through its full range a few times, and recalibrate it in the system settings. In a game, a slightly larger dead zone can also help confirm whether the stick is only just off-centre.
For a quick visual check, try this step-by-step stick-drift check before you open anything.
If the drift is still there after cleaning and recalibration, especially in only one direction, the stick module itself is likely worn. At that point a stick-module repair or a replacement controller is usually more sensible than repeated cleaning.
Disclosure: I run this free tester.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
emisiyas Tafes さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 18
過去 30 日: 39
今までの合計 177
