How to replace the LCD
how to replace a new lcd
この質問は役に立ちましたか?
Your phone, like many Android phones has two different ways you can replace the screen. First is the recommended way, which involves replacing the screen and the frame as a single assembly, while the second method is to replace the screen by itself.
The cost difference between buying the screen+frame assembly vs. just the screen is usually only a few dollars, a cost that is usually offset by the need to buy a tube of adhesive glue if you're doing the screen only replacement, so price isn't really a determining factor here.
With the screen+frame method you will essentially gut the phone, removing all of the internal components and moving them to a new screen+frame chassis. If your frame is bent or has cosmetic issues, this method will take care of that with the result that your phone will look like new again. The process is a bit time-consuming but not particularly difficult, and you won't have to worry about sealing the display against liquid ingress since it comes already mounted on the frame. Here's a guide showing you how to do that replacement.
Manuales / Vivo Y20s / Full screen - Nadie Me Llama Gallina
That video is for the Y20S rather than the Y20, but going through the specifications for the two phones the only difference I could find was that the Y20S comes with more memory.
With the screen only method you have to separate the old display from the frame, clean off the adhesive then glue down the new screen. The procedure is completely different from the other way, so you'll want to go with Harry's search to find a video showing you how to do that.
Good luck, and let us know how it all turns out. I'd be interested in knowing which method you decide on and why you made that choice.
Unfortunately, the Nadie Me Llama Gallina site appears to have been taken over and taken down, so the previous link to their repair guide is no longer usable.
このアンサーは役に立ちましたか?
Yar mera mobile display par line agaya hai ese thik kaise kare
Please kuchh tarika batao vivo y20a ka salyusan mera mobile display mein line agaya hai rat ko pani gira tha
Hindi -> English translation:
Please tell me some solution for Vivo Y20a. There is a line on my mobile display, water fell on it at night.
Unfortunately, water can easily damage your display, so you may end up having to replace the screen. However, it may be that the screen will recover once the water evaporates, although there is always the risk that contaminants in the water could still cause permanent damage.
It would be worth your time to try and get the water to evaporate. Use a hair dryer to heat the screen near the line. Put it on medium heat and blow on it for five minutes at a time. Let it cool down then repeat a few times to see if the line improves. If it does, keep heating and cooling it until the line either goes away or is small or faint enough that it doesn't bother you.
Alternatively, you can place the phone in a bag of silica gel packets, which will absorb moisture. DO NOT PLACE YOUR PHONE IN RICE! Not only does it not work, the rice dust can contaminate your phone.
English - Hindi translation:
दुर्भाग्य से, पानी आपके डिस्प्ले को आसानी से नुकसान पहुँचा सकता है, इसलिए आपको स्क्रीन बदलनी पड़ सकती है। हालाँकि, हो सकता है कि पानी के वाष्पित होने के बाद स्क्रीन ठीक हो जाए, हालाँकि पानी में मौजूद दूषित पदार्थों के स्थायी नुकसान का खतरा हमेशा बना रहता है।
पानी को वाष्पित करने की कोशिश करना आपके समय के लायक होगा। स्क्रीन को लाइन के पास गर्म करने के लिए हेयर ड्रायर का इस्तेमाल करें। इसे मध्यम आँच पर रखें और एक बार में पाँच मिनट तक फूँक मारें। इसे ठंडा होने दें और फिर कुछ बार दोहराएँ ताकि पता चल सके कि लाइन में सुधार होता है या नहीं। अगर ऐसा होता है, तो इसे तब तक गर्म और ठंडा करते रहें जब तक कि लाइन गायब न हो जाए या इतनी छोटी या धुंधली न हो जाए कि आपको परेशानी न हो।
वैकल्पिक रूप से, आप फ़ोन को सिलिका जेल के पैकेट वाले बैग में रख सकते हैं, जो नमी सोख लेगा। अपने फ़ोन को चावल में न रखें! यह न केवल काम नहीं करता, बल्कि चावल का चूर्ण आपके फ़ोन को दूषित कर सकता है।
cara nak tukar lcd
Hi,
Here’s a list of several videos for Vivo Y20 screen replacement:
https://duckduckgo.com/?q=vivo+y20+scree...
You should find one that is suitable for you to follow and you may even want to create a guide to help others.
Hope this helps
このアンサーは役に立ちましたか?
Unke camere mein jo gand Mar jata hai use kaise saaf Karen
過去 24時間: 17
過去 7 日: 106
過去 30 日: 237
今までの合計 6,399
13 件のコメント
I have a new lcd and it doesn't touch
Granville さんによる 共有
@granville70096
Have you checked that the new lcd module flex cable is securely connected to the systemboard?
Are you sure that you got the correct display module for the phone?
Was there other damage to the phone besides needing a new display assembly?
jayeff さんによる 共有
Cara mengganti lcd
Ato Brebes さんによる 共有
Display gone
Gokulnath K さんによる 共有
My screen damage
Triloki Singh さんによる 共有
8件以上のコメントを表示
