メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Desire 816は、1280x720解像度の5.5インチディスプレイ、13MPのリアカメラ、そしてHTC BoomSoundを搭載しています。
HTC816G my folder is damage
htc 816g overheating and screen folder boken
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
For your HTC 816G experiencing overheating and a broken screen folder, here’s a step-by-step guide to addressing these issues:
Overheating Issue:
  1. Check for Background Apps:
    • Close unused apps: Go to Settings > Apps and close or uninstall apps that are not needed.
    • Check for apps using excessive resources: Look at the battery usage stats in Settings > Battery.
  2. Update Software:
    • Ensure your phone’s software is up-to-date. Go to Settings > About phone > System updates.
  3. Restart Your Phone:
    • A simple restart can sometimes resolve overheating issues. Press and hold the Power button and select Restart.
  4. Check for External Factors:
    • Avoid direct sunlight and remove any case or cover that might be insulating heat.
    • Ensure the charging port is not clogged with dust.
  5. Battery Health:
    • If the overheating persists, the battery might be faulty. If your phone is under warranty, consider getting it checked or replaced by a professional.
  6. Factory Reset:
    • As a last resort, you can reset your phone to factory settings. Make sure to back up your data before doing this: Settings > Backup & reset > Factory data reset.
Broken Screen Folder:
  1. Inspect the Damage:
    • Determine if the screen is cracked, the digitizer (touch functionality) is broken, or if the screen is simply detached from the frame.
  2. Temporary Fix:
    • Use screen protectors or tape to prevent further damage. This is a temporary measure and should not be used as a long-term solution.
  3. Replacement:
    • Order a replacement screen and digitizer assembly if you’re comfortable with DIY repairs. For HTC 816G, you might find parts online or from a repair shop.
    • Follow a detailed guide or video tutorial for replacing the screen. It usually involves:
      • Removing the back cover and screws.
      • Disconnecting the battery and screen connectors.
      • Replacing the screen and reassembling the phone.
  4. Professional Repair:
    • Visit a repair shop: If you’re not comfortable with DIY repairs or if you want to ensure a professional job, taking the phone to a certified technician is recommended. They will have the proper tools and experience to replace the screen folder safely.
Important Considerations:
  • Warranty: If your HTC 816G is still under warranty, check if the repair can be covered by the warranty.
  • DIY Repair Risks: Replacing the screen yourself can void warranties and potentially cause further damage if not done correctly. If you choose to go this route, make sure you follow guides closely and handle components carefully.
  • Send me a Video or Picture about the problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pradeep Gupta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 203
