Drivers for iPod Shuffle
computer crashed , need installation drivers for iPod Shuffle 2nd generation model 1204
この質問は役に立ちましたか?
この質問は役に立ちましたか?
jh195831, I have not seen any specific drivers for the Shuffle. All you have to do is what Apple says here: "iOS devices require Apple Mobile Device Support, which should be automatically installed with iTunes. To verify whether it is installed, follow the steps appropriate for your Windows operating system below.
Windows XP: Click Start and choose Control Panel. Open the "Add or Remove Programs" control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs.
Windows Vista and Windows 7: Click Start and choose Control Panel. Click "Uninstall a program" (or if using Windows Vista's Classic View of the Control Panel, click "Programs and Features"). Verify that Apple Mobile Device Support is visible in the list of currently installed programs.
If Apple Mobile Device Support is not listed, remove iTunes, QuickTime, Apple Software Update, Apple Application Support, and then reinstall iTunes."
This should enable your computer to find the iPod the next time it is plugged in.
このアンサーは役に立ちましたか?
still my ipod 2nd gen does not work
このアンサーは役に立ちましたか?
iPod Shuffle 2nd generation will be detected and work only with Windows XP with itunes installed.
This is some software issue or upgrade that windows above XP is not detecting iPod Shuffle.
I have tried all sort of things posted on internet to make it work, but none works. With trial and failure have figured it out and posting here.
Give it a try, will surely work for you.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 41
今までの合計 19,582
