Failing to run software update
Hi, my desktop rolls back windows 10 updates when I am trying to run updates. How can I solve this problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well I will suggest you to checkout the following video it might help you in fixing the issue which you are facing: https://www.youtube.com/watch?v=-SgSFn35...
このアンサーは役に立ちましたか?
Thank you very much @gtip for the post. I think it would help for sure but it needs gurus I would say. I don't think I can to do it on my own I am not as tech savvy as this guy in the video. I appreciate.
Try running the Windows Update troubleshooter and check if that fixes the problem or if it shows any error codes when trying to fix it.
このアンサーは役に立ちましたか?
Hi @jayeff, the troubleshooter did not help. I had already tried it numerous times.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 30
今までの合計 355
