メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
NintendoのSwitchシステム向けに製造された、ワイヤレスで従来型のビデオゲームコントローラー。モデル番号:HAC-013。
Pro Controller Left Joystick Input Dropout
My left joystick's input seems to dropout momentarily, especially when I push it in any direction in the top half of the joystick (i.e. directly up, up-left, up-right, etc.). I already tried taking the controller apart and putting cleaning solution in the joystick (i.e. BW-100), but it only solves the problem temporarily. Is there anything else I can do that doesn't involve replacing the joystick?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
i’m afraid that you do need to replace it… when you test the joystick in the settings menu of the Switch, what are the results? Maybe you can just calibrate it. Is the controller also up to date?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I did recalibrate, but the issue didn't completely go away. When I move the joystick around the upper edge of the left joystick, there's the dropout is less pronounced but still there. Controller is up to date.
EDIT: Slight edit for clarity.
さんによる 共有
Alright, then I’m afraid that you do need to replace it :(… you do need to solder and have some solder experience. I replaced some of them and the good thing is, is that the solder melt really easily and that replacing it is easier then like the PS4 controller joysticks.
さんによる 共有
コメントを追加
回答を追加する
smoothbrain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 271
