メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
show generator code 4 instead of 1
hey, fellas need help with vellylab force fx c esu as it shows the generator code 4 instead of 1 . after calibration, the error 212 remains constant.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @abhijeetchauhan
According to p.6-10 (p.132/214) of the service manual, a code 4 error indicates a CPU test failed.
An error code 212 (see p.6-17, p.139/214) indicates a ram malfunction.
Try replacing the coin cell battery in the generator, then recalibrate it and check if that resolves the problem - see Correcting Battery-Backed RAM Malfunctions on p.6-26 (p.148/214). The coin cell battery model number should be stamped on the battery. Note: Be sure to remember which way the original battery was inserted so that you insert the replacement battery the same way
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
hi @jayeff
Thank you for the detailed explanation. I understand the steps you mentioned regarding the error codes. However, my concern is that even after recalibrating the equipment as per the manual, the error code 212 persists.
Additionally, I'm noticing something unusual. According to the VellyLab FX-C manual, the generator code should be 1 for the VellyLab C model and 4 for the VellyLab 8C model. In my case, I’m working with the VellyLab C model, but it’s displaying a code 4 instead of 1. Could this be related to the unresolved issue? Any further guidance on this discrepancy would be appreciated.
さんによる 共有
@abhijeetchauhan
Did you try replacing the coin cell battery as suggested?
It is related to error 212
さんによる 共有
I have same problem what should i do solve the problem error 212 and 216
さんによる 共有
@mdabdulawalawal
See my answer regarding 212, it relates to 216 as well. Read the manual (linked above) about 216.
さんによる 共有
I followed your instruction and set date and time but not remove error 212
Reenter the calibration mode and then date and time ok
But not remove error 212.
Have any option to manually remove the error 212.
さんによる 共有
4件以上のコメントを表示
コメントを追加
回答を追加する
abhijeet chauhan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 611
