メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Elite Wireless Controller Series 2は2019年11月4日に発売され、Xbox One、X、Sコンソール、およびWindows 10/11搭載PCと互換性があります。モデル1797。
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
さんによる
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
さんによる
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
さんによる
コメントを追加
Its possible you are screwing the screws too tightly wgen you reassemble the controller. Try to loosen them a little. It might work
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Any fix? I have one with the same problem
さんによる
コメントを追加
回答を追加する
Matthew Riordan さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 60
今までの合計 587
