メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Patagoniaのアウターウェアは体を寒冷時には温め、雨天の日にはドライに保ってくれます。修理の難易度は簡単な継接ぎ作業から複雑なバッフル作業まで様々です。
Drawstring is tearing through jacket fabric
Drawstring in my patagonia puffy hoody is tearing through fabric on waist.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@mike85647 if anybody on here knows, it'll be @mariaparker The iFixit textile repair Guru
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Thanks @oldturkey03 :) @mike85647 It's probably best to reinforce the part where the drawstring is wearing through. You could either sew a strip of fabric onto it (should work similarly to the procedure of sewing a patch onto a pillow, see my guide here), or attach a strip of sticky fabric. There are iron-on fabrics and patches you could use, in that case be careful not to melt the fabric of your jacket if it's made from artificial fibers like nylon or polyester - put a tea towel or a sheet on top before you start ironing.
But you can also get stick-on patches that you don't have to iron on (this one is an example in a German store), that would be better if your jacket is made from nylon, polyester or other artificial fibers. If your jacket is mostly cotton, an iron-on patch should work fine.
Just to be sure, could you upload a picture of your jacket?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 33
今までの合計 261
